Hi all!
I have the following rig -
CPU - Core 2 Duo e4500 2.2Ghz( OCed to 2.6Ghz, now running at stock again)
Motherboard - Gigabyte P35-S3G
Ram - 2x 2GB Corsair DDR2 800
GPU - MSI 8800gt 512mb Factory overclocked
PSU - Corsair VX 450W
HDD - 1x 320GB Seagate 7200rpm running Linux Mint 17.1 64bit
1x 1TB Samsung 7200rpm running Windows 7 32 bit and storage
Case - CoolerMaster RC330 with one case fan plugged into the motherboard
Keyboard - Basic PS/2 TVS Keyboard
Mouse - Microsoft Comfort Optical Mouse 3000 USB, with both the clicks not working properly. The left click has degraded in the past month or so
For the past few months, my system has been restarting abruptly while using it. First it restarted randomly and booted back up to either OS. Then slowly the problem got worse and it kept restarting more often. Then it stopped even going to the BIOS and the fans would just spin on and off. After getting the motherboard repaired, it seemed to be fine. But after a few weeks another problem popped up! The keyboard started behaving erractically and a few restarts after the system wouldn't go past the first BIOS screen. It would simply keep restarting. I got the motherboard repaired again, thinking that the previous guy didn't do it correctly. The repair guy returned my machine just this sunday after repairing it and it seems the abrupt restarts are back. They happen after fairly long usage and the system restarts back fully to the OS. I have tried the following to rule out some components -
1) Hard Disks - Both OS are installed separately on each hard disk. Suspecting it was an OS problem, I tried both the OSes but the system still restarted abruptly.
2) Graphics card - When the system was not booting past the first BIOS screen, I replaced my 8800gt with an old ATI card that can run just off the pci-ex slot. Unfortunately, it still didnt boot past the BIOS screen at that time. So I reckon the graphics card is not at fault here.
3) Memory - I will be mem-testing it today overnight. One peculiar thing I have noticed is that in the BIOS, there is a value called DDR18V which is 1.9V. In HWMonitor, VIN1 is showing up as 1.936V.Assuming VIN1 and DDR18V are signifying the current ram voltage and that my RAM is rated to run at 1.8V, could there be a problem here?
This leaves out the motherboard and the power supply.
1) PSU - I haven't tested the PSU myself yet as there is no one I know that has a decent power supply. The repair guy doesn't have a PSU with a 6pin connection for the gfx card (odd i know!)to test whether there's a fault with mine. My hypothesis here is that the PSU is damaging the motherboard over time. Is there any way to test the PSU? I can get access to a multimeter for voltage measurements,etc.
2)Motherboard - Either my repair guy is making a fool out of me or he is not diagnosing the fault correctly. He said that this time he changed the BIOS chip but the problem seems to persist. The only improvement is that the system is fully usable after the abrupt restart. It might be that something on the motherboard is not working properly which is damaging other components. What could that possibly be? How could I check it?
I have already spent 20 quid on repairing this board, but being a greenie, I dont want to simply throw it away. Recycling is pretty crap where I live but repair's cheap. Moreover, getting a decent future proof machine going to cost me atleast 200 quid which I dont have spare right now.
I have attached a HWMonitor text file in case its helpful. - http://speedy.sh/5b6Bc/AbruptRestart1.txt
Please let me know if you have any suggestions on what could be the problem and how to go about diagnosing and fixing it. Thanks!
