System restarts everytime
Vivek Kairi
41
System Information (local)
computer name: VIVEK-PC
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
Hardware: DL-G41MX3-LT, Intel
CPU: GenuineIntel Pentium(R) Dual-Core CPU E5700 @ 3.00GHz Intel586, level: 6
2 logical processors, active mask: 3
RAM: 2146684928 total
Graphic Card: GeForce GT 430 1GB
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Wed 3/25/2015 2:10:08 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\032515-18096-01.dmp
This was probably caused by the following module: dxgkrnl.sys (dxgkrnl+0x8CFB3)
Bugcheck code: 0x116 (0xFFFFFFFF85192510, 0xFFFFFFFF91E52272, 0xFFFFFFFFC000009A, 0x4)
Error: VIDEO_TDR_ERROR
file path: C:\Windows\system32\drivers\dxgkrnl.sys
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: DirectX Graphics Kernel
Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
On Wed 3/25/2015 2:02:46 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\032515-17799-01.dmp
Bugcheck code: 0x116 (0xFFFFFFFF85338008, 0xFFFFFFFF91E24272, 0xFFFFFFFFC000009A, 0x4)
On Tue 3/24/2015 3:52:42 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\032515-27253-01.dmp
Bugcheck code: 0x116 (0xFFFFFFFF851AB008, 0xFFFFFFFF93E28272, 0xFFFFFFFFC000009A, 0x4)
On Tue 3/24/2015 7:57:04 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\032415-26832-01.dmp
Bugcheck code: 0x116 (0xFFFFFFFF852D7008, 0xFFFFFFFF93A42272, 0xFFFFFFFFC000009A, 0x4)
On Tue 3/24/2015 5:44:49 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\032415-26707-01.dmp
Bugcheck code: 0x116 (0xFFFFFFFF853DB510, 0xFFFFFFFF91E56272, 0xFFFFFFFFC000009A, 0x4)
On Tue 3/24/2015 5:23:18 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\032415-18002-01.dmp
Bugcheck code: 0x116 (0xFFFFFFFF8862E510, 0xFFFFFFFF93256272, 0xFFFFFFFFC000009A, 0x4)
On Mon 3/23/2015 3:30:20 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\032415-27799-01.dmp
Bugcheck code: 0x116 (0xFFFFFFFF87783510, 0xFFFFFFFF91E2D272, 0xFFFFFFFFC000009A, 0x4)
On Wed 3/18/2015 6:18:44 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\031815-22432-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x31829B)
Bugcheck code: 0x124 (0x0, 0xFFFFFFFF85C4E024, 0x0, 0x0)
Error: WHEA_UNCORRECTABLE_ERROR
file path: C:\Windows\system32\ntoskrnl.exe
description: NT Kernel & System
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Sun 3/15/2015 8:40:45 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\031515-27534-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x316F63)
Bugcheck code: 0x124 (0x0, 0xFFFFFFFF85C3E024, 0x0, 0x0)
On Sun 3/15/2015 7:33:29 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\031515-21294-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFFFFFF85C574DC, 0x0, 0x0)
tried it but no luck
Again crashed
On Thu 3/26/2015 3:56:21 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\032615-30295-01.dmp
Bugcheck code: 0x116 (0xFFFFFFFF85284008, 0xFFFFFFFF91E37272, 0xFFFFFFFFC000009A, 0x4)
Sounds like a dead GPU. "This indicates that an attempt to reset the display driver and recover from a timeout failed. " Very bad, i had a gpu die on me this same way 2 years back. Did you completely uninstall and reinstall the driver?
