System Review and Analysis
lmvienna
Hello everyone, good morning.
I am aiming to build a super budget PC and got myself some parts on Craigslist and Kleinanzeigen. The question is, does anyone knows how will it run? Or if something doesn't work, what? I did my homework and the parts SHOULD be compatible.
http://de.pcpartpicker.com/user/xxViennaxx/saved/LrkQzy
The Q6600 is the G0 version, as I plan on overclocking it to at least 3.2GHz. The RAM is 1066MHz to open up the OC headroom a little and I have the maximum possible, 8GB on the Asus P5K SE/EPU motherboard, which has 1600 FSB and accepts up to 1200MHz RAM.
The GPU is not yet defined, as I don't know if a GTX650 Ti or a R7 260X would be better/cheaper. However, 450W from Be quiet! should be enough.
All in all, I want to know if it will run well (60 FPS on medium/high) and if I can make something better. I do not care for a SSD (yeah, I know. My previous build has one, I will miss it), as this PC will not be a long term solution.
Thanks in advance!
