[SOLVED] System runs for 30s after boot, then reboots
Feb 20, 2019
16
Hi guys,
I recently got all components I ordered for building my first PC.
When I connected everything and pressed the power button, PC turns on and stays that way for about 30 seconds and then reboots. And continues along the same pattern.
I tried everything suggested in the sticky in this forum, and so I'm asking for some specific help.
Here are the specs:
Processor: Ryzen 5 1600x
Cooler: Hyper 212 turbo LED
Motherboard: ASROCK b450m pro4
PSU: Corsair VS 550
RAM: Crucial CT8G4DFS824A.C8FE (8GB DDR4 2400Mhz UDIMM)
GPU: GTX 1060 3gb gigabyte windforce oc
I know that this RAM is not compatible, but I tried turning it on without the RAM and same issue. Also when I connected the GPU, fans start spinning couple of seconds after initial boot, then stop spinning, and I did not get any display output to the monitor.
So I decided to remove the GPU until I fix the booting problem.
So my question is, if I get compatible RAM sticks, will this solve my problem? Or could the problem be more serious?
Thanks
Thanks, I will check the link out. I tried what you suggested as well, still the same issue. I didn't get any output on the monitor so I left the gpu out
