[SOLVED] System stability help
connor.aldis98
Hi guys, I purchased my pc in January and have always felt as if something was a bit off.
I am able to run games without any major problems but the stability of my Fps doesn't seem right. I don't feel like I'm getting 100% out of my build. I have run 3dmark stress tests and come out with a 98% pass rate but gaming doesn't live up to that score. Is there any components I need to change out?
I carried over my previous hard drive from a 10 year old build. Could this be the problem? I have purchased a new hard drive so I'm hoping this will fix this.
Processor -
Ryzen 1700x
Ram -
2x hyperx 8gb ddr4
Motherboard -
GA-AB350-Gaming 3
Graphics card -
NVIDIA GeForce GTX 1080
Storage -
2 tb Seagate hard drive
Kingston 120gb ssd x2
bios up to date?
chipset driver up to date?
ssd is that high usage? what using it? something not right, are you sure the system using a 16GB or just 8GB?
replace the ram with a faster ram kit.
connor.aldis98
yes im still using the sticks below :) -
28,192 MB Corsair DDR4 @ 2,128 MHzModule 28,192 MB Kingston DDR4 @ 2,128 MHz
Psu - corsair vs650
https://www.amazon.co.uk/Corsair-CP-9020098-UK-PLUS-Power-Supply/dp/B00PGUSEBG/ref=mp_s_a_1_5?ie=UTF8&qid=1543436674&sr=8-5&pi=AC_SX236_SY340_FMwebp_QL65&keywords=corsair+vs650&dpPl=1&dpID=51iQMUA2TxL&ref=plSrch
Cpu temp
Avg - 44 °c
Lowest -40
Highest -49
Gpu - gpu starting hitting around 80 which I didn't like so I turned up the fans and hasn't reduced the heat from 80 to low 70s
Avg- 75
Lowest - 72
Highest - 80
Hard drive usage hits does hit 100% from time to time but would average around 98%
I've had promblems with the hard drive staying at 100% no matter what I'm doing but that seems to happen at random times.
rgd1101
Don't
ram look fine.
