Hi everyone. I have a new rig that I built under the direction of someone else. It was my first computer that didn't come out of box, and there seems to be a few stability issues. I don't have access to the person who helped me build it any more, so I'm hoping you guys can help me out.
Basically, what happens is that it will occasionally load slow, hang up on stupid things, or have trouble handling some graphics things. It also has some issues reading any of the donut discs. Since this isn't a prebuild, I wanted to see if there was something I could do to try and fix up some of these issues. Below is my hardware and system specs (pulled from steam mainly, notes added with //). Please ask questions if I miss something, and I'll try to answer as best I can. Hopefully you fine folks will be able to help me out!
Processor Information:
Vendor: AuthenticAMD
//AMD Phenom II X6 1100T Black Edition
Speed: 3300 Mhz
6 logical processors
6 physical processors
HyperThreading: Unsupported
FCMOV: Supported
SSE2: Supported
SSE3: Supported
SSSE3: Supported
SSE4a: Supported
SSE41: Unsupported
SSE42: Unsupported
//Not overclocked in the least
//Heatsink:
//XIGMATEK Aegir SD128264
//Motherboard:
//ASUS M4N98TD EVO AM3 NVIDIA nForce 980a SLI ATX AMD Motherboard
Operating System Version:
Windows 7 (64 bit)
NTFS: Supported
Crypto Provider Codes: Supported 323 0x0 0x0 0x0
Video Card:
Driver: NVIDIA GeForce GTX 560 Ti
DirectX Driver Name: atklumdisp.dll
Driver Version: 8.17.12.6644
DirectX Driver Version: 7.14.10.304
Driver Date: 27 Dec 2010
Desktop Color Depth: 32 bits per pixel
Monitor Refresh Rate: 60 Hz
DirectX Card: NVIDIA GeForce GTX 560 Ti
VendorID: 0x10de
DeviceID: 0x1200
Number of Monitors: 2
Number of Logical Video Cards: 2
SLI Detected (2 GPUs)
Primary Display Resolution: 1920 x 1080
Desktop Resolution: 3360 x 1080
Primary Display Size: 26.65" x 15.00" (30.55" diag)
67.7cm x 38.1cm (77.6cm diag)
Primary Bus: PCI Express 16x
Primary VRAM: 1024 MB
Supported MSAA Modes: 2x 4x 8x
Sound card:
Audio device: Speakers (VIA High Definition A
Memory:
//G.SKILL Ripjaws Series (4 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) F3-10666CL7D-4GBRH
RAM: 8191 Mb
//HD:
// 3x Seagate Barracuda Green ST1500DL003 RAID5 configured
Miscellaneous:
//Power supply: Rosewill LIGHTNING Series LIGHTNING-800 800W
//Case: NZXT Phantom PHAN-001WT
UI Language: English
Microphone: Not set
Media Type: DVD
Total Hard Disk Space Available: 2097050 Mb
Largest Free Hard Disk Block: 1985293 Mb
OS Install Date: Sep 26 2011
Game Controller: None detected
//Disc Drives: DVD: LITE-ON iHAS424-98, Blu-ray: LITE-ON iHOS104-08
Speed: 3300 Mhz
FCMOV: Supported
SSE2: Supported
SSE3: Supported
SSSE3: Supported
SSE4a: Supported
SSE41: Unsupported
SSE42: Unsupported
//Heatsink:
//Motherboard:
Windows 7 (64 bit)
NTFS: Supported
Video Card:
VendorID: 0x10de
DeviceID: 0x1200
Sound card:
Memory:
RAM: 8191 Mb
//HD:
Miscellaneous:
Microphone: Not set
Media Type: DVD
