System Standby Failing to Work
dazzaledorf
Hello,
My computer will lock or freeze after being idle for a period of time. When it does this I have to kill power and restart the computer. I receive an error message that indicates that a HP Drinter driver seems to causing the problem. It is the driver for my HP Officejet J4580 All in One Printer. I have reloaded the program several times and even tried to up date the driver from HP. I have also experienced problems with HP Solution Center. For some unknown reason it tries to reload itself after a reboot.I am at a loss as to what is the problem. Perhaps someone out there can provide suggestions for correcting this problem.
If you are utilizing Standby Mode, sleep or hibernate don't !
Set your Power options in Control Panel
