Hello,
So I just hoovered my PC and now when I try and turn it on does as the title says. My specs are as follows:
i5 2500k
Xfx 7970
Asus p8z-68-v lx
Noctua CPU fan
Ccivo atx-900w
Corsair vengeance 16gb 4x4
Thanks
It means that although the Coolermaster GX is good for the wattage on its label, it wanders out of spec under heavy loads. So, don't try to pull any more than 600W out of it, even though it's labeled for more, or your system may become unstable.
Hopefully that is just a symptom of a short circuit. Recheck all of your power connectors.
It is also possible that you killed your system with static. A vacuum-cleaner (i.e. a Hoover) should never be used to clean dust out of a PC. Dust moving up the hose will create destructive static. Use a pressurized duster (outdoors on a good day) to blow it out.
A 550W PSU is sufficient for a HD7970 (that's what I used with mine for the few months I mined with it). It must be a quality PSU however. What you've got may have a "900W" label on it, but may be good for half that. A PSU built by Seasonic (their own, XFX, some Antec), or Superflower (Rosewill Capstone, 80+ gold EVGA) will be good for what is on their label (and then some). Note that the commonly-available and inexpensive Corsair "CX" and "GS" units are not good PSUs. Initially good for their labels, they contain inferior Samxon capacitors that degrade rapidly.
Uh oh...
Other than the V-series (made by Seasonic), most CM PSUs are only a step or two above "junk." Treat a 750W CM PSU like a 600W unit, and you may be okay.
