System State vs Restore Point
bobw
29
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
In XP Pro (SP2), is doing a System State backup the same as creating a
Restore Point?
System state is more complicated then sysrestore. It will copy active
directory structure and sysvol folder too.
Cankat Akdemir
Author of "Windows XP Secrets"
"BobW" <BobW@discussions.microsoft.com>, haber iletisinde þunlarý
yazdý:13ECCD75-4A94-47BB-942E-3DC92C69AC56@microsoft.com...
> Restore Point?
Cankat,
Thank you. My reason for asking is that I can schedule a backup but can't
schedule a Restore Point. Will avoid a few self-inflicted foot wounds.
Thanks again,
Bobw
> Cankat Akdemir
> > Restore Point?
Robert,
Thank you for your help. It shall be done. Yes, all my "backups" are put on
a removable disk drive.
Thanks again. Your advice is sincerely appreciated.
BobW.
"Robert Moir" wrote:
> BobW wrote:
> > Cankat,
> > can't schedule a Restore Point. Will avoid a few self-inflicted foot
> > wounds.
> A backup of your system to removable media is of much more value than
> creating a restore point.
> However, you can schedule a restore point creation as follows.
> Paste the following two lines of code into notepad. Then save the file with
> a .vbs extention, e.g. save it as something like 'restorepoint.vbs'
> Set IRP = getobject("winmgmts:\\.\root\default:Systemrestore")
> MYRP = IRP.createrestorepoint ("Robert's Restore Point", 0, 100)
> with that done, run the file manually, then open system restore and verify
> the restore point was created ok.
> Now you can use scheduled tasks in the normal way to create a restore point
> as you wish. Needless to say, the account you schedule this to run under
> will need to be an admin account.
> Rob Moir
> Website - http://www.robertmoir.co.uk
> Virtual PC 2004 FAQ - http://www.robertmoir.co.uk/win/VirtualPC2004FAQ.html
> Kazaa - Software update services for your Viruses and Spyware.
