Hi,
I had a BSOD while playing a game and could not start Windows since. The message was "🙁 Your PC run into a problem and will need to restart. We'll restart for you". At the bottom of the same screen it said: "System Thread Exception Not Handled". Most of the Internet sources explain this error as "old graphic card drivers" related.
The PC then restarted but as soon as I saw the Windows 10 Logo the same BSOD screen appeared again which caused another reboot resulting in another BSOD, etc. Every 3 or so restarts "Preparing Automatic Repair" was showing up under the Windows Logo but seconds later the very same BSOD would reboot my PC not allowing for any repairs to be conducted.
I interrupted that by going into BIOS where I changed the boot option to USB and inserted my Windows Installation USB into the port. After a restart, through a DOS-like screen (I never saw the blue background Windows screen with Repair, Troubleshooting etc) I was given options to either Install Windows 10 64bit or check the memory. Pressing F8 on the first option revealed other possibilities including Safe Mode which I was reading on the forums about already. Unfortunately, choosing that option had the same results as if I was starting Windows normally - same BSOD. I have later checked each and every possibility from that F8 menu and realized that no matter which one I go for the same BSOD will occur.
I have since disconnected all USB devices (including mouse and keyboard at some point) but there was no change in the PC's behavior. As I own an ASUS ROG Maximus VIII Formula motherboard I was able to identify the Q-Code as being "AE" which is "Legacy Boot Event" and as far as I understand it, it means there is no OS to be loaded - which could mean that there is no working drive visible to BIOS... (SSD failure? But it so then why won't the USB Installation start???).
My system is installed on a Kingston SSD in AHCI mode. I've had it for 4 months. I have not been overclocking any of my setup's components nor have I noticed any overheating. Here are my specs:
- Intel Core i7-6700K 4GHz Socket 1151 8MB L3 Cache
- Noctua NH-D15 Dual Radiator Quiet CPU Cooler with two NH-A15 Fans
- Asus Maximus VIII Formula Z170 Socket 1151 HDMI DisplayPort 8 Channel Audio ATX Motherboard
- Corsair Vengeance LED 16GB (2 x 8GB) DDR4 DRAM 3000MHz C15 Memory Kit
- EVGA GeForce GTX 1080 FTW 8GB GDDR5X DVI-D HDMI 3x DisplayPort PCI-E
- Kingston SSDNow UV400 240GB 2.5inch SATAIII SSD
Please, help if you can..
