System to max out battlefield 4?
joejoeboom
41
What would be the cheapest system needed to max out battlefield 4? I figured an amd proc/gpu would be the best since battlefield 4 has mantle. Any help is greatly appreciated!
This build will easily max out BF4.
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor ($184.99 @ Newegg)
Motherboard: Asus H81M-D PLUS Micro ATX LGA1150 Motherboard ($44.49 @ Newegg)
Memory: G.Skill Sniper 8GB (2 x 4GB) DDR3-1600 Memory ($79.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($54.98 @ OutletPC)
Video Card: Sapphire Radeon R9 280 3GB Dual-X Video Card...
This would be a really good PC to max out Battlefield 4
CPU: AMD FX-8350 4.0GHz 8-Core Processor ($169.99 @ Newegg)
Motherboard: MSI 970 GAMING ATX AM3+ Motherboard ($89.89 @ Newegg)
Memory: AMD Radeon R9 Gamer Series 8GB (2 x 4GB) DDR3-2133 Memory ($79.99 @ Amazon)
Storage: Western Digital WD Blue 1TB 2.5" 5400RPM Internal Hard Drive ($67.99 @ Amazon)
Video Card: XFX Radeon R9 290 4GB Double Dissipation Video Card ($269.99 @ Amazon)
Case: Cooler Master HAF 922 (Black) ATX Mid Tower Case ($89.99 @ Newegg)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($104.99 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($16.99 @ Newegg)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) ($102.98 @ Newegg)
Total: $992.80
Generated by PCPartPicker 2014-11-11 13:15 EST-0500
Video Card: Sapphire Radeon R9 280 3GB Dual-X Video Card ($164.99 @ Newegg)
Case: Corsair SPEC-03 Red ATX Mid Tower Case ($39.99 @ Newegg)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply ($44.99 @ NCIX US)
Total: $601.42
Generated by PCPartPicker 2014-11-11 13:21 EST-0500
With any of these systems you will be doing some heavy duty gaming. It would be wise to get an aftermarket Cooler.
I recommend a Coolermaster Hyper 212 Evo.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-CPU+Fans+%26+Heatsinks-_-N82E16835103099&gclid=CIav_tKc88ECFQmDfgodMGQApg
Your cpu will love you for it.
AF cooler is only needed in the fx 8350 cpu build because it have the OC ability intel locked doesn't need an af cooler.
Just for reference.
+130 Core clock
+330 Memory Clock
8350 @ 4.3Ghz (Stock cooler with stock voltages)
I am able to play BF4, and Crysis 3 maxed out with my rig. I have lowerd Crysis 3 settings tho so it sits average near 50-70 fps.
I am able to run BF4 maxed out with 60-120 FPS. Lowest FPS was in the 50s on siege of Shanghai(map has an fps issue)
Unigine Valley Score:
Preset: Extreme HD
Score: 2566
Min: 25.6FPS
Max 124FPS
