im looking for a program that can replace the wondows 7 taskbar and system tray.
ive tried using objectdock since it has a system tray and start button replacement, but they dont currently support 64bit operating systems. i use objectdock as my dock for applications.
if anyone can suggest a replacement program, or a fix for objectdock 64 bit, i would be greatly appreciative.
p.s. whatever program you suggest should allow for customizable icons and skins.
