Hello guys,
The issue I faced today is that my system suddenly crashed while I was watching Netflix, my display went black its power light started blinking as to indicate no signal so I looked into the casing through its glass panel and my GPU's lights were off but my CPU cooler lights were "ON" and so were my front facing FAN lights, now I didn't get the time in the frustration to check the motherboard lights I tried shutting it by holding the power button for half a minute or so but that didn't help so I turned off the PSU button opened the case just to inspect if there's any physical harm which could be seen, but I didn't find anything.
Specs
Ryzen 5 1600x (No OC)
16gb Corsair 8x8 3200Mhz
Asus Prime X370 Pro
Cooler master 212 Turbo led Red
Aorus GTX 1060 6gb rev 2.0
2 TB Seagate
550 Watt Corsair PSU
Spec-04 Casing with one front facing FAN
Nothing is overclocked on this system except the ram to 2999mhz which the guys who I bought it from did after assembly.
Now I bought it last Saturday and its been working fine even though I made it for my work I didnt actually find the time to do benchmarks its only been 3 to 4 days. Just tried one game Hellblade Senua's Sacrifice which seems to work brilliantly.
What do you guys suggest I should do? Every thing is in warranty but still I want run some benchmarks etc if there are any so that I know if its working fine or not.
Would appreciate the help thanks in advance.
Specs
Asus Prime X370 Pro
2 TB Seagate
