[SOLVED] System Upgrade Advice
Tom_77
17
I currently have a 1050 ti 4GB, i5-2500 and 16gb ddr3 RAM, I use the system for gaming but have noticed that my frame rate seems to vary quite a lot and does at time struggle to stay above 60 fps,
My question is what would be the most effective component to upgrade in terms of price to performance, which upgrade will give me the best fps increase.
Thanks :D
stonecarver
Upstanding
Nov 18, 2019
366
55
290
18
CPU depends on what game's your playing if you actually need the I7's 8 threads................................................ +2 %
https://cpu.userbenchmark.com/Compare/Intel-Core-i7-2600-vs-Intel-Core-i5-2500/620vsm517
Here is where you will do improvement.......................................................... 60% gain
https://gpu.userbenchmark.com/Compare/Nvidia-GTX-1060-6GB-vs-Nvidia-GTX-1050-Ti/3639vs3649
Even a GTX 970 that is considered old news still gives +65 %
https://gpu.userbenchmark.com/Compare/Nvidia-GTX-970-vs-Nvidia-GTX-1050-Ti/2577vs3649
The only reason I did not give ATI advice card is Don't know what your motherboard is and if your running UEFI or Legacy Bios.
And yes so many other options for video card but just wanted to jump start your thinking with simple drop in parts to match what you have.
Reactions: Tom_77
stonecarver
Upstanding
Nov 18, 2019
366
55
290
18
Reactions: Tom_77
Tom_77
17
Thanks for the help :D!
