[SOLVED] System Upgrade Need advice
Jul 18, 2020
Hi i currently have a acer aspire m5811 desktop pc however i would like to upgrade the components as it has now got slow and old. What bundle would you recommend where i will be able to run a few games (valorent, warzone). i would like to keep components that dont need changing if possible so i can to keep costs down. Thanks in advance im totally new to all this.
  1. Windows 8.1 pro
  2. Intel Core i5-650 (4M, 3.20 GHz)
  3. 6GB DDR3 Ram
  4. 1TB GB 5400RPM
  5. DVD RW Dual Layer Super Multi
6 .NVIDIA GeForce GT 320 1GB DDR3 memory up to 2431MB
7 .Power supply: 500 W
https://icecat.biz/en/p/acer/pt.sdge2.066/aspire-pcs-workstations-m5811-4692278.html
  1. Windows 8.1 pro
  3. 6GB DDR3 Ram
  4. 1TB GB 5400RPM
As it is an older system, keep your upgrade costs down. I would upgrade...
  1. Windows 8.1 pro
  3. 6GB DDR3 Ram
  4. 1TB GB 5400RPM
As it is an older system, keep your upgrade costs down. I would upgrade the GPU (like a GTX 1650 (about $150)and add an SSD (like a Crucial MX500 500GB (about $70). Anything more warrants considering a new build and looking at a Ryzen system.
