System Upgrade Suggestions.
danielmoore2276
93
I recently bought a Asus HD 7770 2GB DDR5 graphics card for my computer, I've noticed it been overheating then compared to normal,
I need to buy a New PSU with more power then compared to the one i currently have which is a 500w.
So what PSU power would be idea? and can i still use my 6 pin to molex wire or would it be best to buy a PSU with 2 x 6 pin.
I also want to buy a new tower with 2 x fans already installed so i have checked this one and wanted an input if it would be good.
http://
And as a addition support for the cooling system, would this be a good additional or waste of money
http://
Motherboard - Gigabyte F2A55M-DS2 Motherboard (rev. 1.0) A Series/Athlon Socket FM2 AMD A55 Micro-ATX Gigabit LAN
CPU - AMD Athlon II X4 Core 4 (740) 3.2GHz Processor 4MB
RAM - 2 X 4GB DDR3 RAM (8GB)
GRAPHICS CARD - Asus HD 7770 2GB DDR5
WINDOWS 7
ehbe62phz
http://
it's happened once, that the screen flickers and went off once, i shut off my computer for 30 minutes and it all worked again. Can't remember who but i was told my graphics card would be ok on the psu i have but upgrading it would be idea.
All that pic shows is that cpretemp doe snot support your CPU. It says 0 degrees. This means your CPU is not supported.
An hd7770 is a low end card that could easily run on a 400w unit let alone a 400w unit. Power is NOT the problem as long as it is a quality PSU. What brand and model is it?
Also, what is the GPU temp?
The PSU is a Ace 500W BR Black PSU
http://
GPU at idol is at 41C
I have looked at those makes, and they do look good but there quite expensive and outside of my budget.
I did found one which is quite popular, Arctic Red 650W Power Supply. Dunno if it's any good.
