Question system upgrade
Sav4
349
8
18,865
Im looking to upgrade my aging 4770k platform to the z790 series.It will be used for gaming and streaming, with little video editing.
This is the build and will pair it with my RTX2080 Link to build: bit.ly/3T2Xxnb https://pcpartpicker.com/list/rGNftn
Anything im missing or should consider ?
Thank you
Thank you
I would look at a less expensive motherboard.
https://www.ple.com.au/Products/655128/msi-pro-z790-a-wifi-lga1700-atx-desktop-motherboard
MSI PRO Z790-A WIFI $499.00
https://www.msi.com/Motherboard/PRO-Z790-A-WIFI
I normally buy Asus m/b and im used to their bios. Never had a MSI before, will research the one you linked. Thanks for your input
Here's another option to look at.
https://www.ple.com.au/Products/649377/msi-mag-z690-torpedo-lga1700-atx-desktop-motherboard
MSI MAG Z690 Torpedo DDR5 $371.00
https://www.msi.com/Motherboard/MAG-Z690-TORPEDO
Air cooling or a 240mm AIO will work fine for this cpu.
https://www.ple.com.au/Products/650...core-20-thread-up-to-49ghz-lga1700-retail-box
Intel Core i7 12700 $569.00
https://ark.intel.com/content/www/u...12700-processor-25m-cache-up-to-4-90-ghz.html
That cpu averages one less fps than the 12700K / 12700KF which isn't far behind the 13700K.
