Tohst :
yoji :
Close a few Chrome tabs?
Cheers
I've only got 5 tabs open
I was being flippant.. you said "there are many "Google Chrome (32 bit)" processes running " so it was an obvious comment.
But really - it should not be complicated..
Look at all the processes.. and see whats using the memory.. if you need them all - live with it
if you don't.. get rid of them..
Usually it might be because you have loads of stuff starting up with windows you don't really need/want.. e.g. do you really need Steam to startup with windows?
And you don't say how much mem you have? if you only have 2GB.. 30% at idle may not be too unreasonable.
If you have 32GB.... 30% would be a LOT.
Cheers
