"system volume information" is taking up half my disk space
wa2b
Hi all,
I've just discovered this and looks like a PITA.
It's taking up over 200GB of my 478GB disk.
It says access denied if I try to delete it.
I went into System properties: the protections are all set to "off", I've lowered the max disc usage to 10% (down from 50%)
Why has it been creating so much data?
How can I get rid of it?
Thanks for your help
PS I'm running Win7 home edition so there is no "local users and groups" in my "computer management " panel... (so I can't create that real administrator account which would allow me to then go delete the files - as I've read in another thread)
Disable system restore, then if something is in those folder/s you can delete them
It's one thing I do, after I install Windows
I disable it for good, I dont need it
Thanks for the reply, but I can't open the folder. It remained invisible until I used Treesize to see it.
Also, I can't seem to get into real administrator mode, which would allow me to empty the folder I guess.
PS. Yes the above worked.
in control panel system protection, configure, turn off, lower max usage and delete restore points.
Freed 200GB
Thanks a lot
