Question System will not boot with my rx 5700 xt!
Mikkel_1989
18
Here's my issue!
A few months ago, I purchased an rx 5700 xt (gigabyte gaming oc) to replace my gtx 1050 (prior to this I owned an r9 270x, working flawlessly).
Had a few issues getting my system to boot with the new card plugged in, but I managed to get it working after switching around some cables to the monitor (using a dp-cable).
Now, a couple months later, I am encountering the same problem - only now it persists. Here's the problem:
- When I boot up the computer, all lights turn on, fans are running, but there is no action on the monitor. My keyboard doesn't light up either. I found a workaround that more or less works everytime, but it's extremely impractical and quite irritating. I turn of the pc, switch the monitor cable from the gpu to the motherboard, unplug the psu cables from the gpu, and can succesfully boot the system. I now shut down the pc, switch back the monitor cable to the gpu, as well as plugging in power to the gpu, and then boot - now it boots succesfully..... until I decide to shut down the pc and turn it back on - then it wont boot and I have to repeat the steps again.
Hope some of you might have an idea of what's causing this
Thanks in advance
Ferimer
625
44
19,040
6
Here's my issue!
Thanks in advance
When you installed the new GPU did you remove all the drivers of the old GPU? as well as the integrated Graphics on the board?
Mikkel_1989
18
Yeah, did a clean install of windows, removing everything in the process... then installed it. regarding the integrated graphics... am I supposed to remove that?
