System Will Not Boot
Kyronea
18
I was upgrading my home-built system, swapping out the motherboard, video card, CPU, and RAM.
These are the new components:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813186144 --Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115057 --CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227324 --RAM (4 Sticks)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814187037 --Video card
I kept everything else I'd had before, which included a wireless card, three harddrives, and a sound card, with a 650W Rosewill power supply.
As far as I am aware, the RAM and CPU are compatible with the motherboard. But no matter what I do, I cannot get the system to boot. The onboard LED codes flash FF, then 03, and then the system resets. All fans spin, all LEDs are lit. The speaker is plugged in, but I get no beeps.
I have already RMA'd the motherboard, CPU, and RAM concurrently, and have been trying to get this system to work since May 12th. I just got the RMA'd CPU and RAM today and am experiencing the exact same problem, so it is not a case of faulty parts as far as I can tell.
There are no extra mounts under the motherboard. So it's not shorting out. And everything else is hooked up properly, thermal grease with the stock fan for the CPU was properly applied...everything.
I would greatly appreciate any help you here could offer.
What does the motherboard owners manual say the "03" code means? Have you gone to the motherboard manufacturer's web site and checked to see if the Q8400 is supported by the BIOS version on your board? That's a pretty new CPU and I wouldn't be surprised if the board needs an updated BIOS to work correctly. Have you gone through all the steps in the "READ before posting about boot problems!" sticky at the top of the forum?
http://www.tomshardware.com/forum/261145-31-read-posting-boot-problems
Kyronea
18
Yes, I went through the steps.
The motherboard manufacturer's website does not tell me the codes. I had to find them elsewhere. According to the list I found, it means "03 Initial Superio_Early_Init switch"
Which means nothing to me.
As for the PSU, it was working completely fine before I started swapping out the motherboards, and it hasn't been used for all that long either, so there's no reason it should be failing.
Kyronea
18
How would I get replacement BIOS chips, then?
EDIT: Nevermind; I found the FOXConn phone number and with the quick call they're sending me replacement chips.
Thank you for helping me out.
Rogue77777
334
Have you treid using only two sticks of Ram?
xaira
i hope you realise that this board is meant to be liquid cooled also does the ps ur using have a proper eps 12v 8 pin connector to power the cpu. those are the only 2 problems i can see.
Kyronea
18
It is supposed to be liquid cooled? As in, it requires liquid cooling?
I thought that was an optional feature. I have two 120 mm fans; they should be good enough, right?
Kyronea
18
I did have one more question actually.
My motherboard's eight pin CPU power plug has its holes shaped like this:
S(Square) R(Round
RSSR
SRRS
Now, my power supply has a twin four pin/four pin set that is meant to be plugged into this. One of the four pins looks like this:
SR
RS
But the other looks like this:
RR
RR
Now, I can plug both four pin connectors into the whole eight pin thing and it seems to fit properly, but I have to ask if that's what I should do or not, because I don't know very much about the specifics of this particular bit of the hardware of PSUs or motherboards, and I'm pretty sure they wouldn't shape the pins differently if there wasn't a requirement for them to align properly.
xaira
unplug the extra four so only four pins are connected like this
