I am having issues getting my new home built system to post. Right now I have the mobo and psu laying on the desk with an old case speaker hooked up. I have also installed the cpu, heat sink (artic silver 5), RAM, and video card.
When I power it up I hear no audible warnings. The CPU fan turns on as does the fan on the GPU but I get no display. I have tried each stick of RAM separately in each slot. I have removed the GPU. Still no post.
Can anyone see anything wrong with this set up that might keep it from posting? Any advice welcome.
Specs:
GIGABYTE GA-MA790XT-UD4P AM3 DDR3 AMD 790X ATX AMD Motherboard
AMD Phenom II X3 720 2.8GHz 3 x 512KB L2 Cache 6MB L3 Cache Socket AM3 95W Triple-Core Black Processor
XIGMATEK Dark Knight-S1283V 120mm Long Life Bearing CPU Cooler
OCZ Platinum 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory Model OCZ3P16004GK
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
XFX HD-487A-ZHDC Radeon HD 4870 1GB XXX 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card
Specs:
