I've been using same system for a year now without any problems. Decided to change GPU and update OS SSD. After I got everything connected and tried to boot and nothing happened. Fans dont move an inch, no indication whatsoever about boot sequence. Only thing is RGB on mobo lights up when I turn PSU switch on.
I've done every step on the stickied troubleshoot post. I bought new PSU (was about to upgrade it anyways) and new case. I've tried using old GPU again, switching ram slots and so on with no help.
Weirdest part is it worked just fine beforehand. I didnt change anything that would affect the power up of the computer.
You guys got any ideas? Did I really brick my MB somehow in the process?
Specs:
Asus Tuf B550-Plus
R5 3600 + stock cooler
Kingston Fury 3600 16gb
Evga 750w PSU
RTX 3060
Specs:
Asus Tuf B550-Plus
Evga 750w PSU
RTX 3060
