System won't respond suddenly
Arsalan91
14
Hello everyone,
My system is 1 year old now, and recently i started having this problem that when I am using my suddenly the monitors will turn off but the lights on keyboard, mouse, case fan is all on and all the fans are working but the pc wont respond at all. Even thought the reset and power button also don't works. I hold power button for nearly a minute but still it won't work. The only way i can get the PC back to work is pull the power cable from the PSU and wait for 30 seconds then plug the power cable back to PSU. It happens once a day everyday, now its getting annoying and I am pretty sure its not good for the components that I am pulling the power cable from PSU. Can anyone help me out what with what is the issue or any one had similar problem? My PC specs are below
CPU: AMD Ryzen 5 1600X
MB: Asus Prime X370-Pro
RAM: 32Gb DDR4 Corsair
Graphics Card: MSI GTX1060 6GB
CPU Cooler: Cooler Master Seison 240P
PSU: Thermaltake 850W 80+Gold
What does that means? Is my power supply bad? Because the power supply is fairly new.
