Hello Tom's Hardware community,
First off, I apologize for reposting this. I'm having issues trying to update my previous post to show my updates and am still stuck without a solution.
I've recently purchased all brand new parts for building a custom PC. My knowledge in building up from scratch is extremely limited so I had a good friend of mine help out. After putting everything together, the system doesn't boot; not a single part powers up. (I've tried with two different power supplies now -- the wall outlet works; it's powering my main light.)
(Apologies in advanced for the unorganized cables -- I didn't want to zip-tie anything until the whole system is running properly.)
PARTS LIST
Motherboard: ASRock Z97 Extreme4 LGA 1150 (HDMI Sata 6Gb/s)
CPU: Intel Core i5-4960K Quad-Core 3.5GHz (LGA 1150)
GPU: ZOTAC GeForce GTX 970 4GB 256-Bit DDR5 (SLI and G-SYNC Support)
RAM: 8Gb DDR3 1866 (2x4Gb)
SSD: 120Gb SATA III
HHD: 2TB 64Mb Cache 6.0Gb/s
Power: Antec 850W
Case: Rosewill Challenger, Mid Tower (3 fans)
Optical Drive: Asus 24X DVD Burner
Network Card: Rosewill Dual-Band Wireless N900 Wi-Fi Adapter
All parts were purchased from Newegg.
Overview of system:
This is where I had the most uncertainty. (The following pictures will explain more.)
Here is where those three connections get input on the motherboard:
And after connecting them. I'm not certain of the positive and negative sides but when troubleshooting, I tested as pictured and reversing where the white wire is on each.
Here is the manual for connecting the headers:
The last thing I wasn't quite certain of was with the GPU power supply connection. It's pictured closest to the camera in slot "+12V1" although it doesn't seem right to me that there are all those extra female inputs available even though I have nowhere else for the GPU connector to go and that's the only type that came with the PSU.
http://
Please let me know if additional photos are needed.
Thanks!
- Jared
PARTS LIST
SSD: 120Gb SATA III
Power: Antec 850W
Overview of system:
http://
Thanks!
- Jared
