Sorry about the weird subject, hard to explain the problem with as few words as possible...
My desktop won't turn on unless I use the cable for the RESET button. If I wire it correctly, it simply won't turn on I started the computer using a jumper instead of the cable, and I then tried the resetbutton (which was still wired to reset, as it should) and the computer restarted.
So, from that I know that the motherboard is OK, and the resetcable is OK, so I switched places with the power and reset cable and voila! The reset button now starts the computer, and the power button now restarts it xD so the power cable IS working, it just only works when wired to reset...
I also tried flipping the cable so + and - (or whatever it is...) switched place, but nope, that's not it.
