does that happen in safe mode?
on logon screen, open the power menu in bottom right
while holding left shift, click restart button
this restarts windows in a blue menu
choose troubleshoot
choose advanced
choose start up options
click the restart button
choose a safe mode (it doesn't matter which) by using number associated with it.
Pc will restart and load safe mode
is it the same or normal? from one fix I found, its likely it won't help
You may need to reset windows to fix it.
ltt link
