SYSTEM_SERVICE_EXCEPTION and IRQL NOT LESS OR EQUAL BSOD ERRORS
Thomas_294
So I have been trying to fix these two BSOD errors I get quite commonly whilst gaming, but otherwise, when I'm just using my computer for browsing and what not, it's fine.
I have looked at hundreds of past threads and nothing has helped, I have two recent dumps here;
crash dump file: C:\Windows\Minidump\061417-20500-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x14A6F0)
Bugcheck code: 0xA (0xFFFFF804EA14FE60, 0x2, 0x0, 0xFFFFF803C5528E2B)
Error: IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\Windows\Minidump\061517-27593-01.dmp
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF803A6B1AEC0, 0xFFFFA6813FC16F80, 0x0)
Error: SYSTEM_SERVICE_EXCEPTION
Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code.
