Systems Keeps Reebooting
confuseis
29
Hi All
My Machine keeps reebooting! Nothing has changed recently as this machine is not used much.
There is no blue screen the system just restarts with out warning.
I have checked the c:\windows\minidump for dump files but there is nothing there
I have ran sfc /scannow for windows errors chkdsk /f for hard drive errors.
I have made sure windows has all updates.
CPU Temperature at 52 Celcius
I have run a hardware diagnostoic and all the hardware passes.
The Power supply is a high end one and rated for well Wattages wellabove what is needed on the machine 1000W.
Not sure what to do next. Any suggestions
Thanks
Confuseis
Even a "high end" PSU is not bulletproof. In nearly all cases where the symptoms were the same as you've described, I fixed it with a new PSU (I fix computers for friends in my spare time).
However, in a couple of other cases where those same symptoms occurred it turned out to be a faulty motherboard.
