T:DS - Gamall's Lair - Hidden Door or Doors ?
G
Guest
Guest
Archived from groups: alt.games.thief-dark-project (More info?)
In Her bed chambers. When you go to the book case just to the
right of the bed. There is a hidden switch. It is a book that
will raise up slightly. When you turn Garret to the right.
You can see a stone door opening up with a ladder inside.
There is one switch at the bottom of the ladder as well as at
the top. Also at the top there is loot worth 100 I believe.
The switch at the top of the ladder opens up a seond stone/wall
door that allows you to look down upon that huge statue at the
end of the room with the loot as bait in the center of the room.
My friend says he remembers an addional switch of some kind in
Her lair but at the present time is unable to recall what the
switch looked like or where it is.
The U.S.A. retail version with version 1.1 patch.
Does any one know where other secrets are?
Geneve
"If confused why this or that is going on."
"I suggest you go to http://www.timdoc.com"
"Geneve" <a@n.com> wrote in message
news:ctllo7015a5@drn.newsguy.com
> the
> that
> right.
> as at the top. Also at the top there is loot worth 100 I
> believe.
> stone/wall
> at the
> the room.
> kind in
> the switch looked like or where it is.
We'd tell you, but it's a secret.
>> the
>> that
>> right.
>> believe.
>> stone/wall
>> at the
>> the room.
>> kind in
Snot nosed brat.
(grin)
Geneve
news:ctmgci014rs@drn.newsguy.com
>>> kind in
>>> what the switch looked like or where it is.
> Snot nosed brat.
You guessed !!
> (grin)
X
> Geneve
Slept since I played, but I think there was another
on a different bookcase or where some pots and
pans were.
