T:DS - Screen Capture - Is it possible inside a mission?
G
Guest
Guest
Archived from groups: alt.games.thief-dark-project (More info?)
T😀S - Screen Capture - Is it possible inside a mission?
"If confused why this or that is going on."
"I suggest you go to http://www.timdoc.com"
Not that I'm aware of. You can use the Print Screen key and then paste the
resulting BMP into any paint program, but that's pretty tedious. Best to
use a screen grabber like FRAPS.
Cheers,
Mike
