T.Force Delta R RGB SSD RGB ISSUE
Ahmed_Khaleel
21
I wana buy this T.Force Delta R RGB 250GB ssd its rgb just need usb 2 9 pin to operate the rainbow effect my motherboard msi z370 a pro have 2 usb 2 9 pins already in use and i dont have more the version of ssd available in my country the version r i suppose you all will say get yourself nzxt hub but iam sorry to tell you that it is not available and if you order it from amazon it will cost me alot i was thniking to use usb - micro usb cable to connect the micro with ssd and the usb to usb2 port from the motherboard from i/o shield behind the case is will work without a problems this my think for cheap solution until i get the nzxt hub in the future
