B BlazGr Prominent Jul 9, 2017 31 0 530 Feb 11, 2018 #1 So I have a Samusng Note 10.1 2014 Edition Android powered tablet. I had it for about 3 and a half years now. And as expected battery is starting to die . So do wht do you think I should do to fix the battery problem?
Solution Phillip Corcoran Feb 11, 2018 You will have to buy a new battery for it, it's a DIY job: Instructional guide: https://www.ifixit.com/Guide/Samsung+Galaxy+Note+10.1+Battery+Replacement/30608
S sizzling Titan Oct 18, 2006 27,218 3,268 112,240 Feb 11, 2018 #2 Find a local shop that can replace the battery. Upvote 0 Downvote
photonboy Titan Jun 20, 2006 21,566 13 85,015 Feb 11, 2018 #3 https://www.youtube.com/watch?v=y7PP4tCJGAQ https://www.ifixit.com/Guide/Samsung+Galaxy+Note+10.1+2014+Battery+Replacement/86078 I am NOT saying this is a good battery. You should Google to try to find a somewhat trustable source (based on comments/scores of purchasers): https://www.fixez.com/samsung-galaxy-note-10-1-inch-2014-battery Upvote 0 Downvote
photonboy Titan Jun 20, 2006 21,566 13 85,015 Feb 11, 2018 #4 sizzling : Find a local shop that can replace the battery. or at least ask how much that will cost because you can do it yourself for probably much less Upvote 0 Downvote
Phillip Corcoran Titan Moderator Sep 7, 2013 26,109 916 120,140 Feb 11, 2018 Solution #5 You will have to buy a new battery for it, it's a DIY job: Instructional guide: https://www.ifixit.com/Guide/Samsung+Galaxy+Note+10.1+Battery+Replacement/30608 Upvote 0 Downvote Solution
