Taking suggestion for pc parts.
AzTec_Warrior
11
Since hl2 went gold iam building me a new pc and need help. I'am taking any suggestions if you guys think i can get better pc parts. I have $3000 to spend and want to make sure that i get my bang for the buck.So plz help me out here casue i need all the help i can get.
Motherboard: ABIT AV8 - VIA K8T800 Pro Motherboard
Processor: AMD Athlon 64 FX-55+ Processor
Memory: 1GB Corsair XMS Dual Channel DDR SDRAM
Video Card: NVIDIA GeForce 6800 Ultra 256MB
Harddrive Serial ATA RAID 0 - 74GB Western Digital Raptor 10,000 RPM w/16MB Cache
Cd-Rom NEC ND-3500 16x Dual Layer DVD±R/W
Sound Card: Creative Sound Blaster Audigy 2 ZS
Power Supply Antec True Control 550
Heatsink Thermalright XP-90
Case Antec P160
Spitfire_x86
Splendid
Jun 26, 2002
7,248
GeForce 6800GT is almost as fast as GeForce 6800 Ultra, but costs less.
If you wait ~1 month, then you can get nForce4 based mobo. At this moment, nForce3 Ultra based mobos are the best.
<A HREF="http://www.foood.net" target="_new">FOOOD's Icons</A>
<A HREF="http://geocities.com/spitfire_x86/myrig.html" target="_new">My Rig</A> & <A HREF="http://geocities.com/spitfire_x86/benchmark.html" target="_new">3DMark score</A>
BeyRevRa
183
From what I have seen on pricewatch, the GT is like 550-650 and the Ultra I didn't even bother to quote. He could SLI 2 6600GTs for 215 a peice and it should outperform the 6800GT pretty significantly for less money.
AMD 64 3400+
MSI K8N Neo Platinum
1 GB Kingston HyperX PC3200
6800 GT
WD Raptor 74GB
BeyRevRa
183
I would suggest wating a month and getting the nforce4, but if you HAVE to get it now, with a budget of 3 grand, here is what I would get:
AMD Athlon 64 90nm 3500+ - $315
MSI K8N Neo2 Platinum - $131
2x DDR400 Crucial Ballistix 512MB - $300
PNY Geforce 6800 GT - $400
Thermaltake Dream Case - $120
WD Raptor 74 GB x 2 Raid 0 - $356
Some Sort of heatsync/fan - $30
2x Lite-On 8x Double Layer - $180
480w Antec True Power - $87.50
At this point the total is about $2,000 and you have a REALLY nice system. Since you wanna spend 3 grand on this, I decided to splurge on the rest of the computer:
Any Mouse and Keyboard, depends on your preference. I have the MX Duo by Logitech so... - $70
Klipsch Promedia Ultra 5.1 - $360
Sound Blaster Audology 2 (optional) - $90
some 19 inch monitor - $250
All this added up, and I might be missing something here I did this kinda fast, comes to be around $2,800. I can't really think of anything else to add to this, maybe use the $200 to buy games or something? I've never gone into building a computer with a $3,000 budget before; but then I usually reuse old parts. Anyway, I am sure there are more knowlegable people here that will suggest better stuff than me, so you should probably listen to them instead. Either way your gonna have a great system.
AMD 64 3400+
6800 GT
WD Raptor 74GB<P ID="edit"><FONT SIZE=-1><EM>Edited by BeyRevRa on 10/23/04 02:40 PM.</EM></FONT></P>
AzTec_Warrior
11
I already have the mouse,21inch lcd monitor, speakers and keyboard. I just want to go all out on with my last pc.Thxs for the help and ideas.Keep them coming i need all the info i can get.
BeyRevRa
183
Yikes... its my understanding that LCDs that big ghost like crazy. 3 grand for a straight computer? Hmmm... I'll do something else up in a second.
AMD 64 3400+
6800 GT
WD Raptor 74GB
BeyRevRa
183
They will be in Mid-November according to the recent press.
AMD 64 3400+
6800 GT
WD Raptor 74GB
