G
Guest
Guest
Archived from groups: comp.sys.hp.hardware (More info?)
A customer of ours runs an overnight backup using an HP SCSI tape streamer -
not sure of the model number, but it is several years old, and uses DDS3
tapes. The OS is Windows 2000 server, and it is using the NTBackup software
supplied with the OS. The problem is that the orange light is flashing on
the front panel, which suggests that the tape drive needs cleaning. He puts
the cleaning cassette in, it cleans the drive, ejects the cassette and the
orange light goes out. Everything seems OK until after the overnight backup,
when the cleaning light is then flashing again. On looking in the backup
log, there are messages about media errors. I would suspect a faulty tape,
but he has 6 tapes, and the all do the same thing. Any suggestions would be
appreciated.
Regards,
Andy Baker
appreciated.
Regards,
Andy Baker
