Question TCL P605 TV will not produce any sound
Paddy98
5
My parents have a TCL P 605 Roku TV. They had a soundbar connected to it via 3.5mm aux cable. My mom attempted to take the sound bar off of the entertainment stand while it was still plugged into the 3.5mm aux port on the TV and tweaked the port.
For a little while, the TV could only produce sound through the soundbar if the audio jack was held in the damaged port at just the right angle. But then, when I was attempting to set the jack in the port in a position that would produce sound, I broke off the aux port because it was already loose. The port was loose inside the TV.
Now the TV will not produce sound of any kind. Even when I change the settings to use the ordinary built-in speakers, the TV produces no sound. Does anybody have any idea what's wrong and how to fix it? Any help would be greatly appreciated. Thanks.
boju
Ambassador
Tv speakers and headphone jack use the same audio board. My guess is something is shorting the audio board or broken/lose wire or foreign metal object landing somewhere it's not suppose to.
Tv repair guy would be recommended so he can repair the audio board and jack.
Reactions: Paddy98
