TCP/IP properties window showing incorrect settings
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: microsoft.public.win2000.general (More info?)
Hi,
We have a weird problem on a Windows 2000 SP3 server (not important but it
is a DC and an Exchange server). The server had to be recovered to a
different hardware platform (IBM to Compaq) due to a hardware problem. After
a sucessful recovery we noticed that the 'Internet Protocol (TCP/IP)
Properties' window was incorrectly showing the network connection as 'obtain
an IP address (or DNS server)automatically', where ipconfig showed the
correct static IP address. We have now repaired the old server and
sucessfully restored the server back to it's IBM hardware and this fault
still exists, so far we have done the following to try and resolve this with
no effect:
1) Removed the network card from device manager and reinstalled using fresh
drivers
2) Manually gone through the registry and cleaned out any GUID references to
old network connections
3) Set the server to use DHCP and then reconfigurd the static IP / DNS /
WINS settings
All tests show the server is using the static IP address as per ipconfig,
however if you make any change in the GUI, without filling in all details
(i.e. just adding a DNS server), and click OK it will then change the
network connection to use DHCP with the static assigned DNS server.
As indicated above if you set all setings in the GUI and click OK it will
correctly apply the settings, but the next time you enter the GUI it shows
you are obtaining automatically.
While this isn't causing a critical issue it is only a matter of time before
someone plays and accedentially sets the NC to use DHCP so if anyone has any
ideas on this issue that would be great.
Thanks in advance
Hi,
I had the same problem.... after our ISA's motherboard burned, I replaced
it with different manufacture.... after booting Windows 2K3 I have noticed
same problem / bug .... after browsing in registry for whole day I managed
somehow to fix it.....
Removing network card from device manager and reinstalled using fresh
drivers wont help
"Leon Leeds" <Leon Leeds@discussions.microsoft.com> wrote in message
news😀D1FEB55-3CE9-4CDA-B350-CF7213A4F66E@microsoft.com...
> Hi,
> After
> 'obtain
> with
> no effect:
> fresh
> drivers
> to
> WINS settings
> before
> any
> Thanks in advance
Hi,
I don't suppose you have any idea where in the registry?
"Hool" wrote:
> Hi,
> drivers wont help
> > Hi,
> > After
> > 'obtain
> > with
> > no effect:
> > fresh
> > drivers
> > to
> > WINS settings
> > before
> > any
> > Thanks in advance
To display hidden devices, non-Plug and Play devices, and devices not
attached to the computer (commonly known as "ghosted" or "phantom" devices)
Save the following two lines as a file then execute.
--------------------------setdev.bat---------------------
set DEVMGR_SHOW_NONPRESENT_DEVICES=1
start devmgmt.msc
Then, View|Show Hidden Devices to remove or reconfigure these devices. Do
not edit the registry.
How to Remove and Reinstall TCP/IP for Windows 2000 (Q285034)
http://support.microsoft.com/?id=285034
Regards,
Dave Patrick ....Please no email replies - reply in newsgroup.
Microsoft Certified Professional
Microsoft MVP [Windows]
http://www.microsoft.com/protect
"Leon Leeds" wrote:
| Hi,
| "Hool" wrote:
| > Hi,
replaced
noticed
managed
| > drivers wont help
| > > Hi,
but it
| > > After
| > > 'obtain
fault
this
| > > with
| > > no effect:
| > > fresh
| > > drivers
references
| > > to
| > > WINS settings
ipconfig,
details
will
shows
| > > before
has
| > > any
| > > Thanks in advance
Thanks for the post, but unfortunately doesn not help.
Kind regards
Leon
> start devmgmt.msc
> Regards,
> "Leon Leeds" wrote:
> | Hi,
> | "Hool" wrote:
> | > Hi,
> replaced
> noticed
> managed
> | > drivers wont help
> | > > Hi,
> but it
> | > > After
> | > > 'obtain
> fault
> this
> | > > with
> | > > no effect:
> | > > fresh
> | > > drivers
> references
> | > > to
> | > > WINS settings
> ipconfig,
> details
> will
> shows
> | > > before
> has
> | > > any
> | > > Thanks in advance
sorry no,
it was almost two years ago 🙁
I think I was searching for IP address as a string
news:4E056AEA-5E19-4874-B39D-75DFCD118089@microsoft.com...
> Hi,
> "Hool" wrote:
>> Hi,
>> replaced
>> noticed
>> managed
>> drivers wont help
>> > Hi,
>> > it
>> > After
>> > 'obtain
>> > fault
>> > with
>> > no effect:
>> > fresh
>> > drivers
>> > references
>> > to
>> > WINS settings
>> > ipconfig,
>> > details
>> > will
>> > shows
>> > before
>> > has
>> > any
>> > Thanks in advance
Hi,
We still haven't resolved this problem. Does anyone have any fresh ideas?
regards
Leon
"Leon Leeds" wrote:
> Hi,
> no effect:
> drivers
> WINS settings
> Thanks in advance
