Looking to build a lower power system and was wondering if gpu tdp is like 140watt, why do they recommend a minimum 500watt psu? going for a 65watt i5 (haswell) also.
The psu will be higher than your actual usage. This is so you are not overworking the psu which will kill it prematurely. Also the best efficiency is ~50% capacity so you want to stick around there with peak at ~70%.
