Review TeamGroup T-Create Expert DDR5-6000 C34 2x32GB Review: Expertly Designed For Professionals
It would be interesting to see how dual rank and single rank kits compare when set to the same clocks and latency. I know in the DDR4 era this could make some difference, but I don't think I've seen any comparisons on new Intel/AMD platforms. Of course single rank kits clock much higher and generally have better timings, but I know at least G.Skill has released some low latency DDR5-6000 dual rank kits.
The T-Create Expert DDR5-6000 C34 currently retails at approximately $176.99. Although not excessively expensive, alternative DDR5-6000 2x32GB options are available on the market at lower prices and with substantially superior timings.
So, what are the other options you speak of? The ones tested against the Tcreate are both substantially more expensive. There doesn’t seem to be many 64gb kits at better$/gb with faster or even equal timings. 32gb kits yes, but not at the higher capacity.
What I see is the same memory used by gamers except without the RGB lighting and over-the-top aesthetics.
For professional use I'd expect system-level ECC. Otherwise it's just cosmetic.
