Archived from groups: rec.games.video.arcade.collecting (
More info?)
You might want to check through the Google archive a bit on this. My
thought was that Goof Off or the like would be too strong - but I see
some have used it sucessfully. I have heard recommendations for 3M
"Safest Stripper" a bit over the years here and I have used it a
couple of times with pretty good results...though I think you could
get heavy handed with anything.
I suspect that it really depends on what kind of paint is on the
cabinet as to how your results will be...
The first time I did this, I applied the stripper to the whole side of
the cabinet at once (laying on it's side) - I then decided the next
time that that was too much area to do all at once.
Good luck!
Mike
On Fri, 1 Jul 2005 22:06:03 -0400, "Keith in NJ" <winner@soulshot.com>
wrote:
>defender and paint.. something i'm intimately familiar with.
>get yourself some goof off... a plastic scraper and a nylon brush.
>spray (or pour) the goof off onto the cabinet (lay it on it's side)..
>agitate it a little with the brush.. let it sit for a few minutes.. spray it
>again...
>start scraping...
>don't worry about using too much goof off... it'll just make things easier.
>here's photos of me doing mine.
>came out VERY excellent.
>haven't taken photos of the final cleaned up result (after wiping the whole
>thing down with goof off on a rag)
>if the art was good when they painted it over you're going to be really
>pleased with a couple of hours work.
>took 3 cans of spray goof off (with about half a can left over)
>http://www.arcadepics.com/4images/categories.php?cat_id=5
>keith
><Go10nks@gmail.com> wrote in message
>news:1120266511.736017.301590@o13g2000cwo.googlegroups.com...
>> I recently bought a Defender cabinet that had the original artwork
>> painted over.
>> *On a side note, I bought it from Mark at MTW Enterprises who
>> was very
>> great to work with. (www.silverballsolutions.com)
>> Anyways, I bought a Defender Cabinet. The original artwork has been
>> painted over. Because the original artwork was painted on, I don't know
>> what to use to remove paint. Any tips are greatly appreciated. Thanks.
