G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
All things being equal (Capacitance Rating, Voltage, Polarity, Leads)
does it matter if its a Ceramic Disk, or an Electrolytic, or a Mylar,
or one of the other kinds of capacitors?
I am looking to replace the 0.1uF 500v caps across the switch contacts
of my F-14 and the local electronic store only has mylar capacitors at
this voltage level (or higher), but the guy the works there can only
say "maybe" it will work.
Which I don't understand - shouldn't a capacitor be a capacitor - I
understand physical dimensions may cause problems in certain
environments, but that's not a huge issue inside a pin cabinet.
