G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting (More info?)
I have a centipede upright that was working fine until I had it for a
few days 🙁
It got turned on and off really fast and then stopped working. At first
it was making high pitched sounds and garbage was displaying on the
screen, changing rapidly. The very first time it did this the high
score screen was briefly visable (but garbled). I was getting allot of
beeping noise.
I looked around and did the AR/II 5v sense fix found here
(http://www.stickycarpet.com/pinx/pp2page2.html) and that did change
things. Still getting garbage on the screen but it is less frantic and
more predictable. Still noise but more constant noise.
* Not responsive to the test switch
* All fuses seem OK.
* I checked the voltages on the test points on the ARII board (after the
fix not before). The 5 and 12 volt readings are ok, but the 22 volt
readings are both in the 24 range. Not sure if this is enough to cause
a problem or not.
What else should I test?
Thanks for any help,
Shawn
few days 🙁
beeping noise.
a problem or not.
Shawn
