G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting (More info?)
I have a Q*bert that has had a switching power supply installed along
with the original.
It was working for some time, then I plugged it in, heard the knocker,
and nothing.
Now nothing at all when I plug it in.
I tested the switching power supply outside of the game and it seemed
fine. When everything is hooked up no power is getting to it.
All of the fuses seem fine. I checked on the power brick and the power
supply board. I tested for voltage at the first slam switch and it
seems fine.
There is visable damage to my power supply board, and I don't know if it
was there before, I didn't really inspect the machine when I first got
it. R21 is missing. R22, R12, and R14 are clearly damaged.
I can easily replace those items, but wonder if there is anything else I
should check...and not sure if that is the cause since I don't think any
voltage is getting there in the first place.
Any ideas or suggestions would be appriciated, thanks!
Shawn
with the original.
and nothing.
seems fine.
Shawn
