G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting (More info?)
Kortek monitor woes is right.
This monitor was working fine last Christmas. I lost the blue color
just before I was going to sell it to a customer. I set it aside until
now and troubleshot it.
Found the Q107 neckboard transistor had been bent too far and pulled up
a trace on the mounting pad.
I removed the transistor and fixed the trace and then reinstalled the
transistor.
I had a blue color for just a brief second. The I lost it again.
I pulled the chassis and found that Q104 and Q152 were bad. Replaced
those and tried again. No dice.
This time I took a closer look at the neckboard area and found that I
had installed the Q107 neck board transistor backwards.(Duh) Pulled it
and checked it and it tested good. Replaced the chassis mounted
transistors and tried again.
No luck still. I pulled all the transistors and found that I am still
killing the chassis mounted transistors Q103,Q104, and Q152. Q107 is good.
Where do I go from here? What is killing these transistors?
Is it a result of mounting the neckboard transistor incorrectly? I sure
would appreciate somebody's expertise here. I'm running out of patience
and spare transistors.
Thanks
Pat
transistor.
Thanks
Pat
