Tech: Megatouch Sapphire DBA problem??
G
Guest
Guest
Archived from groups: rec.games.video.arcade.collecting (More info?)
i have a Merit Megatouch Sapphire that i replaced a DBA in and have a stupid
question about!
it is a 2511 U3 VN with a jumper to take new $5 and for amusement acceptance
which i already have in another Touchmaster touchscreen that works fine. my
question is probably easy but i am having troubles with making the $1 give 4
credits and same with $5 giving the correct 20 credits(now gives $1=1cr and
$5=5cr). menus option somewhere i'm missing????
is there an easy solution for my problem? i have went through the menus
several times but can't figure out what i need to do!!!
TIA,
Kelly
G
Guest
Guest
Did you check the dipswitches on the DBA?
Woz
"Kelly Ray" <starwarsroomspam@comcast.net> wrote in message
news:0I-dnTZ0A9b90dPfRVn-gQ@comcast.com...
>stupid question about!
> acceptance which i already have in another Touchmaster touchscreen that
> works fine. my question is probably easy but i am having troubles with
> making the $1 give 4 credits and same with $5 giving the correct 20
> credits(now gives $1=1cr and $5=5cr). menus option somewhere i'm
> missing????
> TIA,
> Kelly
G
Guest
Guest
yes, 2511 has a short and long "pulse" on the dip switches(7 and 8) and have
tried both ways!
"William Wozniak" <wozniak@atlanticbb.net> wrote in message
news:114t5oj8jf62v10@corp.supernews.com...
> Woz
G
Guest
Guest
The VN doesn't have a dip switch for pulses per dollar. See my other reply
in the Rec.games.video.arcade group.
> Woz
> > missing????
> > TIA,
> > Kelly
