Any thoughts on how I would determine if the cause of the problem is the CPU or MOBO? I have already tried a new HD, and I also tested out the two RAM sticks. I ran both sticks individually to see if one of them was the culprit, but the problem did not go away.
The PC boots into windows, I log on, and then shortly after that it slows down and freezes up. The PC stays on, it doesn't blue screen, or go black, it's just frozen.
I have tried multiple complete re installs. It always successfully installs Windows, and even runs for a few hours, but within 24 hours the PC is freezing shortly after windows starts. Any suggestions would be greatly appreciated.
Here is the build:
1) AMD Phenom II X6 1055T Processor (HDT55TFBGRBOX)
2) GIGABYTE GA-990FXA-UD3 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
3) G.SKILL Sniper Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-14900CL9D-8GBSR
4) (initially) Western Digital WD Green WD10EARS 1TB 5400 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
4) (now) Seagate Barracuda ST1000DM003 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
5) EVGA FPB (Free Performance Boost) 768-P3-1360-TR GeForce GTX 460 (Fermi) 768MB 192-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
Here is the build:
