Looking at a review of a Thermalright SI-120, it went into detail on operation of the heat pipe system I had not previously understood.
http://www.systemcooling.com/thermalright_si-120-01.html
But basically it is a phase change process and depends on the condensed fluid flowing back to the heat source (CPU). In the above review, the test was done with the M/B horizontal.
It would seem to me, if I install this in tower case (all I use) where the M/B is vertical, it would appear to me that the condensed fluid would not go to the base but to the pipes near the base. It would appear the cooler would not be as efficient.
Am I missing something or is this an issue for tower users and heat pipe using coolers?
