[SOLVED] tell me a power source compatible with my pc
jesusthekiller
6
Hello good case is that I turned on my computer and everything normal but it took 10 minutes and it suddenly went out and I realized that the power supply had died so I need you to tell me some cheap power supply that is compatible with my PC now I will attach some photos of the power supply and a page where the features of my computer to tell me what source of power can be compatible with my PC and it is cheap I hope you help me thank you very much.
LINK OF THE CHARACTERISTICS OF MY PC (TRANSLATE THE PAGE BECAUSE IT IS IN ANOTHER LANGUAGE): https://www.x-kom.pl/p/288975-desktop-lenovo-h50-50-i5-4460-8gb-1000- dvd-rw-gtx745.html
LINKS OF THE PHOTOS OF MY POWER SUPPLY AND MY OPEN PC:
https://ibb.co/eiJiiL
https://ibb.co/daPdHf
https://ibb.co/mUQJHf
https://ibb.co/cDFw3L
https://ibb.co/is4dHf
https://ibb.co/nbkw3L
https://ibb.co/hveCcf
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply (€69.99 @ Amazon Espana)
Total: €69.99
Generated by PCPartPicker 2018-11-01 19:07 CET+0100
And you will need this adapter for the mainboard power: 14 pin to 24 pin adapter:
N]https://www.amazon.es/Adaptare-35003-ATX-Stromadapter-Netzteil-Mainboard/dp/B00ZRHDQH0/ref=sr_1_1?ie=UTF8&qid=1541095694&sr=8-1&keywords=14+PIN+TO+24+PI
N
Total: €69.99
N
Hi, can you tell me a slightly cheaper power source and would this cable from 14 pin to 24 pin certainly work? https://www.amazon.es/Xiton-Alimentaci%C3%B3n-Principal-Fuente-Adaptador/dp/B07F89C5HY/ref=sr_1_9_sspa?ie=UTF8&qid=1541097424&sr=8-9-spons&keywords=24+pin+a+14&psc=1
Do you know any 300 watt power supply that works on my pc?
And one thing now that I have realized my power supply has two connectors that is the 14 pin and another 4 pin then the one that you have sent me has more sata connectors of graphic card etc .. if I buy the one that you tell me where I would connect the other graphic and sata cables because the power supply that has broken down has only two connectors so if I bought yours the other cables if they were left the PC would only connect the two connectors
