[SOLVED] Temperature i5-7600k AIO
Dec 9, 2018
I overclocked my I5-7600k to 4.9ghz and 1.408v with ASUS program (ai suite 3) and after playing Battlefield V 1h in ultra FHD 60fps is making 78°C with Coolermaster Ml360r watercooling. The case is the envolv x . Is safe this temperatures ?
You can always try walking it back little by little. Just move it down a bit, run some stress tests, and then test it during normal applications. If it seems stable, move it down a bit more and repeat until it is no longer stable at that frequency. I always recommend manually overclocking instead of using auto overclocking tools because they always seem to really crank the voltage up higher than it needs to be.
