Ok, so I get my new E6850 chip to replace my E6600. Plop it in, and temperatures seem to be a little higher than I was used to with the E6600. I used TAT to test (note that the approx 15C correction was added to temp results). With the E6600 I was running about 55C with TAT after 20 minutes. With my E6850 I was running approx 62C after 20 minutes. Not terrible, but not desirable.
So after removing the HSF from the CPU I noticed that little if any AS5 ws touching the heatsink. After doing some forum searching, I found that concave IHS's are none to uncommon, so I decided to lap the IHS and the heatsink since results seemed promising, so went ahead and lapped them. Well, the IHS looked nice and smooth, but the heatsink lapping didn't go so great, as the surface was much more dull than before I started.
I reaassembled the system and while the thermal grease was distributed evenly across the surface, indicating a nice flat surface between the chip and the heatsink, my TAT temperatures were running into 70C+ range!
So I decided to replace my HSF with a new one thinking I might have done more damage than good by lapping it, as this is a quality Zalman HSF (7000). Well, temps are now running about 70C still.
Weird thing is that when I first powered on my PC after using the new heatsink, the idle temps were about 25C. After a couple runs with TAT or Orthos, and cooling down all the way, idle temps are now at about 35C. Ambient room temp is about 20C.
I use only 99.953% isopropyl alcohol for general cleanpup and use the ArtiClean surface purifier from ArcticSilver prior to applying the paste.
Any thoughts or suggestions?
